Sweep pattern on surface
Joakim_KullJoakim_Kull Member Posts: 2
Hello!
I'm trying to create a pattern on a surface consisting of X cuts. For this I've tried using the sweep function with X projected curves with X profile sketches .
The problem is that this is tedious work since I have to model X profile sketches and then create X sweep features. I also want to change the value X without getting too many lost references.
I have recreated a similar design studio that I can share. But the real on has X = approx 100.
https://cad.onshape.com/documents/b8eb0b754a9c8958675f53a2/w/a5e8f8f338c193578b4ffe7f/e/5f9b2ada480292862b3c5674?renderMode=0&uiState=65293ff96a2c4c3c0df20d83
Ideally I'm looking for a way to draw one profile and then select X curves to sweep this profile on in one feature.
Any ideas?
Thanks in advance,
Joakim
  • EvanReeseEvanReese Member, Mentor Posts: 2,869 PRO
    edited October 2023 Answer ✓
    Here's what I think you're after. Let me know if you have questions about what's going on. At an n of 100 it'll probably slow down, but if every sweep path is slightly different I don't see a way around it.
    A few notes:
    - I used Offset Surface to make a surface for Intersection Curve. You could just as well use Plane 1, but the surface can be deleted as part of the pattern so it ends up less cluttered.
    - I used my Profile Sweeper feature, but a regular sweep works too. You'll need to pattern the profile sketch too. Or you can make a custom profile on the top plane to use with Profile Sweeper.
    - I used my Linear Pattern Plus feature for convenient even spacing, but some variables and the normal Linear Pattern would work too.
    https://cad.onshape.com/documents/e467e73f74490237388506d4/w/32a3f3089aeab9259bb62386/e/eb4a2e455f5550d605327f1d
