Configured variable "failed to regen" but the models are fine?
Stormi_Backus
Member Posts: 49 ✭
I have a sprocket configuration that is reporting a variable as having failed to regenerate in the feature tree while it is fine in the physical model. I haven't found a similar forum post and am hoping someone here has an idea why, thanks in advance! Screenshot and link below.
https://cad.onshape.com/documents/2c4f5bab9bc2b79a2bf8961e/w/cbbb46a106a0f0eb2119f71b/e/c4036cc622af110f1715f57f?configuration=Bore_Diameter=0.025400000000000002+meter;List_GadxODcKvYw2yy=_7;List_sUepC7gBBML0fO=Default&renderMode=0&uiState=652957212042183fbd469f9a
EvanReese
Member, Mentor Posts: 2,686 PRO
Not sure why it would matter, but I noticed the variable is set to "Any" not "Number". I changed it to number and it works... but now when I change it back to "Any" it also works 🤷♂️
