Using an offset plane for a sketch
allen_keshishian
Member Posts: 9 ✭
Hello,
I was wondering if this is possible. Let say I have a sketch on a plane. I want to project the same sketch on a plane 15 mm directly below the sketch. Is this possible? This is just a sketch and not a face. I understand I can use "Move Face" to move a surface.. I appreciate the help.
Thank you
Thank you
https://cad.onshape.com/help/#sketch-tools-use.htm?Highlight=USE
Also I have requested control over the chirality of the sketch plane (ie, which way is "up") - you may wish to consider voting for this, under "Improvement Requests", at "Ability to flip orientation of Planes"
