How to connect two lines that are on different planes
cyrus_costa541cyrus_costa541 Member Posts: 54
edited October 2023 in Drawings
I have two points I am trying to connect to fill in an area but the line I want to connect them I need it to curve vertically and horizontally if that makes any sense. Is there a way to do this?
  • EvanReeseEvanReese Member, Mentor Posts: 2,333 ✭✭✭✭✭
    the Fit Spline feature can connect two points with a line. If you need something more complex you can use my Freeform Spline feature to create controlled 3D curves.
    Independent Onshape Consultant | Industrial Designer
  • cyrus_costa541cyrus_costa541 Member Posts: 54
    I cannot access your tool for some reason because whenever I try to sign in it will not let me.
  • wayne_sauderwayne_sauder Member, csevp Posts: 602 PRO
    @Evan_Reese
    It's your enterprise again.  :#
    dah! every time! For future reference you just have to change the enterprise (i.e. "ovyl") name to "cad" in the url, but here's that
    https://cad.onshape.com/documents/cd51f29c6937305f86a9df95/w/86ce0e7568faacfe3963e35b/e/44de484ba0acba52f99fcfc5?aa=true
    @Evan_Reese do you know if there is a way to keep the points showing in the freeform spline because it would be nice to have other points to connect lines to
    Easy to miss with so much going on in the feature, but look for the "keep points" checkbox.
    @Evan_ReeseJust as an update I saw your video and I saw where the keep points check box was but I could not find it when I was working. I cannot scroll or anything its like it just doesn't exist
    @Evan_Reese thanks!
    @Evan_Reese I cannot find the closed points check box. Is it possible to show a picture of where it is located?
    I see a blue dot next to your features, which indicates you're on an older version. You can right click them and update them. You should also right click the feature in your toolbar and update that too, so you're referencing the latest version. If you can't find it after that, let me know.
  • eric_pestyeric_pesty Member Posts: 2,142 PRO
    @cyrus_costa541
    It looks like you might be using an older version of the freeform spline feature based on the blue update icon... I would suggest updating to the latest version.
  • S1monS1mon Member Posts: 3,296 PRO
    Depending on what you want to do with the curves, the native Bridging curve may be easier to use.
