Transform Tool - rotation axis other than entity?
pstary
Member Posts: 1 PRO
I import a screw from McMaster-Carr into the Parts Studio and would like to rotate the part.
So I...
But there is no appropriate entity aligned along the Z-axis on the part itself.
Fortunately, in this case of a socket heads cap screw, one of the hex socket entities is true vertical, giving me the option to choose this as my "Z" axis. But if the part imported with that entity slightly rotated, this would not work.
It appears that the system X, Y and Z axes are not available to use. Isn't it logical to offer the option to rotate about one of these axes? Is there anyone other than me that thinks it would be a good idea to add this option to the Transform tool? Other OnShape tools offer this.
Here is the Transform tool as it is:
The revised Transform "Rotate" tool might look this... offering the current option to rotate on entity as default, with a drop-down menu to chose the X, Y or Z axis.
Perhaps I am missing something. Is there some other mechanism for choosing an axis other than an entity of the part?
If not, do you agree this would be a nice addition?
Thanks.
So I...
- Select the Transform tool
- Choose the Part for the Entity
- Choose Rotate as the transform type
- Choose the axis for the rotation using a part entity
- Enter the rotation angle desired
Thanks.
TimRice
Member, Moderator, Onshape Employees Posts: 315
Great idea for an improvement! As a work around, you could create sketches on the front/right planes and manually create axis at the origin.Tim Rice | User Experience | Support
Onshape, Inc.5 -
philip_thomas
Member, Moderator, Onshape Employees, Developers Posts: 1,381
The best way to do this today is 'Transform by Mate Connector' - this is the all powerful option recently added.
1) Import part
2) Drop Mate connector on the origin
3) Drop mate connector on the head of the bolt
4) Transform (part & mate connector) from MC to MC
This is a very powerful workflow as it works for everything and allow you to go back and edit the angle as well as any offset needed (by editing one or other of the mate connectors)
The obvious improvement here is to allow the generation of mate connectors on the fly.
I use this workflow every day.Philip Thomas - Onshape7
Onshape, Inc.
1) Import part
https://cad.onshape.com/documents/588e53983309240fdb42b079/w/959134864e71ca1631931cf5/e/ad053221e1dee6e56abf21e7
Nice feature, thanks for sharing it
Any chance you could modify it to accept a Mate Connector as an input for the axis? It'd be great to be able to rotate a derived part about the Z-Axis of one of it's mates. This would get rid of needing a sketch.
Cheers,
