Drawing error in brovser
ladislav_schejballadislav_schejbal Member Posts: 9
The browser stopped displaying the quoted text and the arrows of the quotes. In export to pdf and dfx it is fine. The error has been there for several days.
    Report a bug from the ? menu - likely a browser update required or graphics driver.
  • ladislav_schejballadislav_schejbal Member Posts: 9
    The problem will be elsewhere. Firefox does it too.
    The layer exported to dfx under the name Annotation_Text is not displayed. Numbers and arrows are displayed normally until right-clicked. Then it disappears with the end arrows.
    It doesn't work even in old projects where it used to be fine. Windows paths are inscrutable.
    Wait for the others, I can live with it for now (hi), I'll fix it in Librercad. I'll try to contact someone else in the Czech Republic.
  • ludmil_mikecukludmil_mikecuk Member Posts: 2
    Dobrý den,
    přišel jste na něco?
    Doma mi to normálně funguje, vidím kóty hned. Ale na druhém počítači nic. Ale když to otevřu na druhém, vidím je.
    Děkuji
    This was probably due to the small RAM size of the graphics card. With the new ASUS Geforce 730 everything is already okay.
    Now the program works 100%.
    Pravděpodobně to bylo zapříčiněno malou velikostí RAM grafické karty. Došlo nejspíš k přetečení a ztráte dat. s novou ASUS Geforce 730 je všechno již v pořádku.
    for ludvik_miketuk
    Pravdepodobne je program vylepsovan a vznikaji dalsi naroky na pamet. mel jsem jen 512 ramky. nova karta ma 2G. funguje to opet na 100%. zajimavy je prilozeny obr. vlevo v nahledu koty jsou a vpravo uz ne.
