Document
in General
Am I understanding what a document is?
I understand that it like a project.
Any number of assemblies, sub-assemblies and parts are within a document no matter how large it gets to be.
Thus it is possible to have 10 very large projects in the free version and when that limit is reached you can delete old projects or make them public.
Am I off base?
Thanks
Am I off base?
Thanks
https://forum.onshape.com/discussion/1414/nitty-gritty-details-of-free-plan/p1
https://forum.onshape.com/discussion/1026/what-will-be-the-upcoming-changes-to-the-onshape-free-plan
I group in documents:
Motorcycle parts
Household parts
Brackets
Having too many documents is un-manageable and grouping like parts, not necessarily projects is a good idea.
https://www.onshape.com/onshape-project-container-sept-3
So if you have all your brackets in one document and need a new version for one of them - the new version covers all of your brackets.
I would like to have tab history and tab versions.
+1 for tab history and Versions
Wouldn't that be wonderful, I've also been struggling with how to accomplish revisions of individual parts also.
Individual tab history and versions could be an approach that may solve my problems.
Thanks for making the improvement request
We might just have to resign ourselves to not being able to have (as they supposedly say in parts of Italy), both "a full barrel, AND a drunk wife"
In a platform like SolidWorks, you can de-intertwine the relationships defined mutually in-context. You delete all relations that are "in-context". I've done it myself and instructed others to do the same for sake of simplicity of managing the data in the long run, and making use of parts that are then potentially used in other products where the in-context relationships would be doubly confusing.
I wonder if at some point Onshape may allow all bodies defined in a part studio to be saved out to their individual part studios and the in-context relationships "nuked" in a sense. This might signal the end of the layout stage and the beginning of maintaining the data in the long haul.
I wonder if folks will want each document to define only one part number. This would be similar to staying away from the conundrums of having multiple part numbers defined in configurations within a single file. Yes, it demos well and looks really slick - but try managing that information over the long haul compounded by thousands of part numbers in who knows which files.
which is dicing with death in Solidworks (because the likelihood of inadvertent future creation of circular references, hence spontaneous unsupervised size changes), but routine in an Onshape Part Studio ... and the viability of that bi-directional, yet risk-free referencing is one of Onshape's big attractions, it seems to me. Because adjacent parts in the real world DO often have a high degree of mutual interdependence, in contours and features as well as dimensions.
The parts in an Onshape studio do not have individual feature trees -- which is one component of what I meant by "history of parts" -- but there's also the undoable "sequence of operations" history.
The former (I would think) will become almost impossible to repair back to the point of being editable when a significant proportion of relationships and dimensions (including things like extrude distances) are dangling (which would be inevitable after separating "Siamese quintuplets" or worse), and I can't see how it would be realistic to provide any sort of meaningful "sequence of operations" history whatsoever for separated parts, because it would be so full of unexplained holes. (Even the present form is surprisingly difficult to interpret usefully, let alone use in any major way)
So it's arguable that the result of such a separation would offer little advantage over simply saving parts as dumb parasolid bodies.
Maybe there needs to be a quite different environment to support parts released to manufacturing, because the requirements suddenly change drastically at that point, as illustrated by @pete_yodis' example of discrete files for discrete part numbers: highly desirable for manufacturing, but problematic for live design ops.
Many of the advantages of Onshape seem to me to accrue prior to that stage. But I don't pretend to have thought about it in any depth .. yet. Thanks to those who've turned the discussion in this direction: it seems like the right time to be considering these issues.
