Custom Hole Feature
H_WangH_Wang Member Posts: 20 ✭✭
The issue I found was for the tapped hole with counterbore, any modification to the bore sizes, it automatically change the hole to "custom" instead of "ISO", which is OK, but that removes the tapped thread. Tapped holes with counterbore is very useful if you are creating tapped hole for shoulder screws!
    lougallolougallo Member, Moderator, Onshape Employees, Developers Posts: 2,001
    We are aware of this behavior and I will attach you to the issue.
    tim_wheelertim_wheeler Member Posts: 19 PRO
    The hole feature's inadequacy continues to be the one reason we can not migrate our development to the Onshape Platform.  We need pipe threads NPT, BSP BSPP, etc.
    We need drill tip angle variables for standard and custom tooling.
    Theo_RTheo_R Member Posts: 81 PRO
    +1 NPT
    michael3424michael3424 Member Posts: 681 ✭✭✭✭
    edited August 2021
    +2 on NPT hole specs and callouts.  I'd also like the ability to create custom thread pitches (like 1/4-40).  That's needed for some old thread forms in the model engineering community.  Although we can spec an (Onshape) standard thread pitch for the hole when it is created and then revise the hole callout by editing it manually in a drawing, that's a PITA and prone to error error should one forget to make the revision when the drawing is created or maintained.
    paul_bunnellpaul_bunnell Member Posts: 25 EDU
    I just tried modeling a camera adapter that uses T2 threads (M42 with 0.75 pitch) but manual pitch entries don't seem to be allowed.
    martin_kopplowmartin_kopplow Member Posts: 285 PRO
    edited December 2023
    The hole feature and especially the thread tables provided are in need of a big upgrade. These are very essential tools in all CAD and just have to be available in their full glory no questions asked. Else, we designers and engineers, who use threads every day, spend too much time working around the shortcomings.
    - Add all metric/ISO fine threads
    - Make threaded holes recognizeable in the model window (Color code the threads or use a thread mapping)
    - Allow user specified pitch in custom holes
    - Add an option to automatically model the threads in 3D detail (sometimes, especially with large diameter holes, this is necessary).
    - In combination with the latter: Include option to set tolerances on detailed threads for AM.
