How do you simulate a 1 way bearing?
I'm trying to simulate a 1 way bearing (sprag clutch) in an assembly for a ratcheting cvt, any idea on how to make a 1 way rotating mate?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,853
    Hi Caleb, welcome to Onshape!
    Do you actually need to see the sprags move / contact or do you just want one-way rotation? Neither is really possible since Onshape does not support contact or one-way revolve mates. Does it need to be shown only rotating one way?
  • afalzate13afalzate13 Member Posts: 37 PRO
    Still no way to simulate a one way bearing somehow?
  • martin_kopplowmartin_kopplow Member Posts: 776 PRO
    I asked the same maybe half a year ago and was told there isn't. I ended up animating the full reciprocating motion, and then cutting out all reverse movements from the video, so only movement step-by-step in one direction was visible at all times. Still, I think it would help in simulation when there were one-way-bearing constraints in Onshape.
