Assembly won't move into place with a second mate. Both mates become corrupted.
I was able to mate two pentagons by making certain that they shared the same plane. Then I used a circular assembly to complete half of a dodecahedron. However, I can't put two halves together. It appears that the parts don't want to mate if they require a scalene movement. If that makes any sense.
Stepping back, this link is two simple pentagons that won't mate. Thank you, again.
https://cad.onshape.com/documents/3f58ad8962075f836537a73d/w/9586b19ae941d1874ba5f796/e/5b29b7551c8dad940397718c
https://forum.onshape.com/discussion/9107/forum-post-checklist-read-this-first#latest
In particular, note the requirement to make it a "Public Document"
And no bevels
But maybe this will help some being as it is using rounded panels and not ones that are purely flat as appears to be your case with the bevel
For the record — the method to make the panels rounded as shown in the part studio, was something I saw @john_mcclary do, which I thought was pretty slick
https://cad.onshape.com/documents/0fed597386a938c7773d8bd8/w/cbf9d9ba85fbc8c27697a806/e/0efb3c074ab9b559cf288650
