How do I revert to a previous version?
jon_woellhaf
Member Posts: 92 ✭✭✭
I saved version 7, then messed up a few things. How can I revert back to version 7?
jakeramsley
Member, Moderator, Onshape Employees, Developers, csevp Posts: 669
Hi jon_woellhaf,
By looking at the image you posted, I am assuming you are not currently looking at a workspace but some looking at V7. The 'Restore' option will only be available in the flyout if you are in an active workspace. First, click on 'Main' so that you go back to the main workspace, then open the flyout and click on the gear without clicking on the row first. This should give you the option to restore.
Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com5
You have a couple of options if you have a saved version you want to go back to. You can either restore your workspace back to that version or you can create a branch off of that version and work from there.
To restore from a version, open the history/versions flyout and click on the gear for the version you want. There will be an option 'Restore' which will put your current workspace back to the state of version.
Likewise, if you don't want to restore but work on a separate branch, just choose the "Branch to create workspace..." option.
You can delete a "workspace" if you want (right-click on the workspace to see a context menu), but you can delete any specific versions.
Intuitive: Select the version you want to revert to, right click, select restore.
Reality: Select the version you want to delete, right click on the version you want revert to, select restore to version.
Yes, I understand the issue with reverting to a version which is the root of multiple branches, but honestly, sofar I haven't seen any svn/git GUI or IDE with this workflow.
