how to set the export unit equal to the workspace unit and the resolution on fine?
kees_bijkerkees_bijker Member Posts: 170 ✭✭
Hello Onshape friends,
I did something stupid, I changed the export rules and could not get it back to what it was before. So I deleted it and made a new export rule as per default. The rule that applies now is :${name}, which is what I wanted.
But, since I did this the export is now using meters as the unit and the resolution is set to medium every time I restart Onshape. If I set it it remains correct during my session but when I re-log in, it is back to meters and medium resolution. I cannot find the place where to set this. Please can anybody point me to where this setting is hiding?
Many thanks in advance.
  • john_robinson568john_robinson568 Member Posts: 15
    I'm having the same issue, however I didn't touch the export rules beforehand, it just started happening a few days ago. I've looked everywhere, but I can't find the default settings anywhere.
  • kees_bijkerkees_bijker Member Posts: 170 ✭✭
    so maybe it had nothing to do with me changing my export rules? Hmmm, that is interesting.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,925 image
    Looks like a bug - please open a support ticket.
    Done! How long before we can expect somebody to look into this do you think?
    Unlikely before January.
    And Jmoellers has just confirmed it has been accepted as a bug and they will look into it.
  • robert_scott_jr_robert_scott_jr_ Member Posts: 685 ✭✭✭
    Ah! that explains why imports are too tiny to be seen in a slicer. - Scotty
  • david_k_clarkdavid_k_clark Member Posts: 2
    This seems like it's something that has changed over the last couple of days for sure. It might be related to new documents rather than all documents (a doc I started about 3 days ago exports in meters every time I start a new session, but older docs are still in millimetres)
    Is there a bug logged somewhere if info is needed?
    @david_k_clark yes a bug has been filed.
    I opened a bug request and a ticket has been opened.
