Appearance Colours Hex Codes - Do the codes conform to a Standard?
chrisjh777
Member Posts: 209 ✭✭✭✭
I have be experimenting with Appearances (trying to emulate the approximate colours of, say, brass or alochrome 1200S aluminium components. I noticed that there is the capability of inserting a hex code for the desired colour.
I found this website that lists 500 colours including corresponding hex codes: http://cloford.com/resources/colours/500col.htm.
However when I use codes from this site, I get totally different colours.
Is there a list of colours (with associated hex codes) that can be used?
peter_hall
Member Posts: 196 ✭✭✭
@chrisjh777
Try this link and the codes shown here, seems to work well on my computer.
http://www.w3schools.com/html/html_colornames.asp
note the shades and mix button gives access to many more variants of each colour. Hope it helps.
The colours all work well for me, if you still have a problem it might be the browser.5
Hi Peter,
Thanks. Codes work fine from your suggested site. I suspect that the site I found would also work.
I discovered that when I was selecting the hex code, I was inadvertently selecting the hash character as well. This made my light yellow colour very turquoise!!
When I copied and pasted the required code (without the # character), all worked as intended.
Regards
http://www.procato.com/rgb+index/
