Move sketch to the origin
andrea_boschetti
Member Posts: 7 ✭
in General
When I import a sketch sometimes it is imported very far to the origin so is difficult to find it. is it possible to move the sketch to the origin?
thank you in advance
https://cad.onshape.com/documents/b90a63cec600990649097202/w/e4d74e1141bd02032f427eb7/e/2fa4774abb25fa0b115ca56d
Main, transformed by x.y.z o a given distance.
If you don't know the distance or can't measure the distance directly then look at suppressed items to make a sketch that can give measurements.
version 2, transformed by points
I did sketch a new point where I wanted to transform the stl from.
version 1, original location
@robert_scott_jr_ cannot thank you enough for this comment.. I was about to just switch to another tool. 😅
SW developer myself, "naming is hard" is my most used phrase, but the video in this case already uses the terminology that I think the software itself should definitely also use and show.
Having the tool names be "Transform Sketch" and "Transform Parts" instead of "Transform" visible in the command-palette and hover items would make this visible in every tutorial and guide.
From a "freshman" OnShape user coming from other tools, a good portion of the guides, documentation and tutorial seems to miss the: "You are in this mode now, so the same tool name is a totally different tool".
This gets REALLY frustrating, as this is an online tool the first question is always:
"Is the guide obsolete on an older version..? ..or why am I not seeing the tools talked about?"
…which is a super frustrating place to be.
In a way there are 3 transform tools. One in sketcher (non-parametric) which operates on sketch entities, one is a feature in a part studio (parametric) which works on curves, surfaces and parts, and the other is a tool in assembly tabs whenever you select a part or sub-assembly (also non-parametric).
