How to Move a Sketch?
matha_goram144
Member Posts: 11 EDU
I've sketched a rectangle (by center) on the top plane. I would like to move it horizontally and vertically by some discrete values. I have two challenges:
- Firstly, when I try to select the rectangle, only one edge is highlighted. Shouldn't the entire rectangle be selected if I have chosen Rectangle as the Sketch option?
- Secondly, I am unable to locate any Move operation for the rectangle sketch. Is there one?
Thanks.
wayne_sauder
Member, csevp Posts: 646 PRO
@matha_goram144
If I understand correctly you should be dimensioning the sketch from a known point (possibly the origin). Don't forget to fully define your sketch (all black).1
But, just found out, if you head to the tool bar and click on plane then proceed to click on any axis it will allow a new plane to be created, the new plane can then be moved to a desired distance to created another sketch for lofting. So instead of moving the sketch you create a new plane for that sketch to be created on. would post a vid, but screen recorder crashes
