Parametrically set holes along a spiral pattern
diogo_duarte944
Member Posts: 3 ✭
I have this drum made out of a polygonal shape to which I want to add holes which are centred on each face except they are offset along the length of the drum for each subsequent face. In a way it's like having a spiral (as marked in red) around the drum to guide the position of the holes (in blue).
The number of faces on the drum can be parametrically set, and so the number holes too.
EvanReese
Member, Mentor Posts: 2,693 PRO
I'm not sure exactly which variables you want control over, but there's a very "Onshapey" way to do this by patterning variable features. Here's an example. I'm essentially creating a "for loop" with variable features if that means anything to you. Since i use the "feature pattern" I'm able to make the variable called #i grow by 1 with each loop. Making other variables multiplied by #i, I can get them to grow by a specified step each time too.
7
@diogo_duarte944
That was the most efficient way i've seen it done. That's how I do my spiral chutes too.
I think I understand the principle, but I failed to manage incrementing the variable #i Any hints?
