Improvements to Onshape - January 12th, 2024
cody_armstrongcody_armstrong Moderator, Onshape Employees, Developers, csevp Posts: 221
edited February 2024 in New in Onshape
It's the first update of 2024, and we are hitting the ground running. This update includes a number of highly-requested improvements, so we hope you enjoy! Let's dive in.
CAD IMPROVEMENTS
DECALS
You can now insert Decals into Part Studios. Decals are visible in Part Studios, assemblies, and shaded drawing views, and can be useful for inserting company logos or warning/hazard labels.
https://onshape.wistia.com/medias/tj1y7xk92m
OFFSET CURVE
Offset curve allows you to offset an edge as a curve on a face. This has a number of uses, as it makes it easy to create offset curves that are attached to a face.
https://onshape.wistia.com/medias/cjusec3bcy
FILTER BRANCHES
You can now filter the version graph to only show branches with active workspaces. This makes it easier to filter out old information.
https://onshape.wistia.com/medias/xh3q8i73a2
DERIVED IMPROVEMENTS
Hide and show the individual entities inserted using a Derived feature. In the past, this was limited to hiding or showing the entire feature. This also includes custom features that import other features.
https://onshape.wistia.com/medias/pr8xe6ci4j
VIEW-ONLY DISPLAY STATES
Display states can now be shared with View-only permissions. This makes it easier for non-CAD users to navigate a complex assembly.
https://onshape.wistia.com/medias/tv6871g4r1
RELEASE VARIABLE STUDIO
It is now possible to release Variable studios. This allows Variable studios to go through your company's defined approval and release processes.
PROFESSIONAL IMPROVEMENTS
REORDER CUSTOM PROPERTIES
Onshape Professional and Enterprise administrators can now reorder their custom properties. This can be useful when you want the most important properties higher in the list.
https://onshape.wistia.com/medias/vyfxydvvhe
CHANGE DATE FORMAT
It is now possible to change the date format for date type properties in your company settings.
ENTERPRISE IMPROVEMENTS
SCHEDULE REPORTS
Enterprise administrators and Analytics administrators can now schedule reports for custom dashboards to run on a regular basis. The results will be emailed to the defined recipients with a frequency and in a format you choose.
DRAWINGS IMPROVEMENTS
SECTION VIEW IMPROVEMENTS
You can now create a Section view (and Aligned section view) from a Detail view.
https://onshape.wistia.com/medias/hialtzzhq8
DRAWING DEFINITION LIST EXPORT OPTION
When exporting an Inspection table, you can now export all dimensions to CSV with the new "Drawing definition list" export option.
https://onshape.wistia.com/medias/zfxx524g01
LEARNING CENTER IMPROVEMENTS
SELF-GUIDED ONSHAPE BOOTCAMP IN FRENCH, GERMAN, AND SIMPLIFIED CHINESE
Onshape's Self-Guided Bootcamp is now localized in French, German, and Simplified Chinese. The entire interface, closed captions, transcripts, and exercises are now all fully translated to ensure the best learning experience. The language selector is located in the bottom left while you are inside the Learning Center.
ADVANCED PART DESIGN COURSE IMPROVEMENTS
A new video on Decals has been added to the Advanced Part Design Course. It instructs users on utilizing the new Decal feature within a Part Studio.
UNDERSTANDING CURVES COURSE IMPROVEMENTS
A new video on Offset curve has been added to the Understanding Curves course. It instructs users on utilizing the powerful, new Offset curve feature.
«13
  • Nath_McCNath_McC Member Posts: 133 PRO
    Brilliant update. I'm so happy about the change in the default date.
  • glen_dewsburyglen_dewsbury Member Posts: 1,120 PRO
    Excellent round of updates.
  • Cary_BettenhausenCary_Bettenhausen Member Posts: 45 PRO
    Decals, finally. YES!
  • shawn_crockershawn_crocker Member, OS Professional Posts: 900 PRO
    Re ordering custom properties is huge.
  • Marc_MillerMarc_Miller Member Posts: 110 ✭✭✭
    Yay decals! Excellent.
    And the derived improvements is another great one.
    Thank you  :)
  • MichaelPascoeMichaelPascoe Member Posts: 2,483 PRO
    Starting off the year strong, this is an amazing update! Ty Onshape team!
  • jason_1jason_1 Member Posts: 28 PRO
    I think my fav in this list is treating Derives more like folders in the feature tree just because that was one of my first feature requests years ago, but really this whole update is great.
  • Rhett_RobinsonRhett_Robinson Member Posts: 159 PRO
    Wow, we are off to a fantastic start! Offset curve and show/hide capabilities for derived parts are some things my team have been waiting for. Nice work Onshape!
  • don_bdon_b Member Posts: 152 ✭✭
    Tried to find decal and features for derived .....see screen shot .....no joy .....is there a trick for me to get this ?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,887
     See the footnote in the OP 😀 - may have to wait until Monday.
  • paolo_ciancipaolo_cianci Member Posts: 23 PRO
    Section view from a Detail view.
    I hope that the next update will arrive the section view from a broken view.
    found features for derived...on new derived part so that part works.
    ok will wait a while thank you for the heads up....if all else fails "read the instructions"
  • adrian_vlzkzadrian_vlzkz Member, pcbaevp Posts: 295 PRO
    Massive start to the year!  :) great work team
    CAD Engineering Manager
  • BOA_TechnologyBOA_Technology Member, csevp Posts: 4
    We are stoked on the Derived feature improvements. This will be so helpful for master sketch modeling.
    www.boafit.com
  • Josiah_HarthcockJosiah_Harthcock Member Posts: 57 PRO
    Yes please! Looking forward to decals and section views of detail view!
  • Hans_Ole_LeirvikHans_Ole_Leirvik Member Posts: 82 PRO
    Wow, lots of good stuff :)
  • nikhil_shringarpureynikhil_shringarpurey Member Posts: 2
    Nice improvements!  Please don't forget some of the quality of life stuff like direct SVG imports, too! Having DXF only is just too limiting in 2024.
  • christopher_dziubachristopher_dziuba Member Posts: 87 ✭✭
    Holy crapadoodles this is insane! The decals 100% Noice!
    Derive improvements, shared display states & Sections on details will certainly come in mighty handy!
  • martin_kopplowmartin_kopplow Member Posts: 844 PRO
    The offset curve on face is important to me, and also the derived improvements.
    Decals may seem small at first glance, but I missed them and will probably use them a lot, for they make sense in so many small ways. They should get a project or wrap option for all kind of surfaces, though. Thank you!
  • Lucas_KuhnsLucas_Kuhns Member, csevp Posts: 103 PRO
    Very exciting. So happy to see the decals feature. The split face and recolor faces was working but getting to be a very cumbersome process. Since we want our decals to still be parts, I just tested a simple workflow of extruding a simple sketch with the outside dimensions, and sticking the decal to it. Seems to work great!
    Also very stoked about reordering the property fields.
  • danny_paynedanny_payne Member, User Group Leader Posts: 41 PRO
    Great updates. Thank you
  • sebastian_glanznersebastian_glanzner Member, Developers Posts: 454 PRO
    Amazing update! I like the decals a lot!
    Thank you Team Onshape for all your hard work :)
  • jari_laaksonenjari_laaksonen Member Posts: 4
    Could you explain me what's the purpose of decals? I can see them in parts and in assembly, but not in drawings or STL. I would like to place images on my desings so that I could use them directly in laser engravings or CNC.
  • S1monS1mon Member Posts: 3,448 PRO
    edited January 2024
    Hmmm. Somehow I assumed that decals showed up in drawings. Without that they aren't very useful for many applications.
    Edit. Decals DO show up in drawings, but the view has to be a shaded view. As far as I can tell it's not possible to dimension the location of the decal.
    @jari_laaksonen  The STL format doesn't support any sort of texturing. When you export something as STL any texturing or color is lost.
