If I have a shape that I want to split in half, what function should I use?
timothy_lee301
Member Posts: 3 EDU
I want to split it at the red line.
NeilCooke
Moderator, Onshape Employees Posts: 5,980
Create a sketch of the red line on the Right Plane, create a surface extude (Extrude > Surface > Symmetric) making sure it fully intersects your part, then use the Split command.Senior Director, Technical Services, EMEA2
