Limited depth of folder structure
Simon_Bo_JensenSimon_Bo_Jensen Member Posts: 3 PRO
edited January 2024 in Community Support
Hello
Is it correctly understood that the maximum depth of a folder structure within a document is 3 folders? It is the folders containing the part studio, drawing and assembly tabs i am talking about.
BR. Simon
  • martin_kopplowmartin_kopplow Member Posts: 1,197 PRO
    It looks like it. I can, though, create a nested folder three deep, and drop that into another nested folder, so it should create a nesting four or five deep, but then, I can't access Folder 4 or 5. I only get this far:
  • Simon_Bo_JensenSimon_Bo_Jensen Member Posts: 3 PRO
    edited January 2024
    Hello
    That is an interesting workaround, thank you for sharing that. Using this method i can get a folder depth of 4, so one more than before. I can access the fourth folder. I will be using this method short term.
    I do not know how this improvement suggestions are submitted (this is my first post). But I have added the tag 'improvement request', hopefully the Onshape developers will see this and increase the supported folder structure depth supported.
    BR. Simon
    I hadn't tried such deep folder structures before and just assumed the depth would theoretically be infinite. Your finding came as a surprise.
    I find working with deeply nested tab folders a bit hard, for there is no convenient browser for this, resulting in a lot of mouseclicks required to navigate within. So I kept it rather flat for now and didn't yet get past three deep.
    I wonder if some kind of assembly browser would be a solution here, for I mainly use these folders to keep assemblies and their resources together, and to save space in the tab bar, of course. I use in-context part studios a lot, so I get lots of individual part studio tabs to keep track of.
    I could possibly do without the tabs altogether, if a representation was accessible through the tree, I guess. The reason is that I can only have one tab folder open at any one time, then I need to go back to the root folder and follow a different branch. That's time consuming.
    I could also imagine the tab bar being modified such as to allow more than one row of tabs and then represent a folder per row, when expanded.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,968 image
    @martin_kopplow
    I was a bit surprised as well of this folder structure depth limit.
    I agree, there needs to be a good reason to use deep folder structures. In my case it is the simple fact that i have a lot of parts and drawings in the document which i wish to organize in a certain fashion.
    @NielCooke
    Yes, that is a good suggestion
    @NeilCooke , oh, you're right! :s I always seem to forget about hat one.
  • vondes_vodesvondes_vodes Member Posts: 6 ✭✭
    edited January 2025
    You’ve got it right—the folder structure in those tabs is indeed limited to a maximum depth of three folders. While this keeps things manageable and avoids excessive nesting, I can see how it might feel a bit restrictive for complex projects. It reminds me of the mobile-first approach in web design, where simplicity and prioritisation are key to ensuring smooth performance, especially on smaller screens. Just as folder structures are streamlined for usability, mobile-first designs aim to deliver the best experience for users. By the way, if you’re interested in web development, this comparison of react vs reactjs offers some great insights into modern frameworks. Cheers!
