sheet metal bending drawing
alex_vestaalex_vesta Member Posts: 4
Hello, I am new in OnShape.
I'm trying to create sheet metal bending drawing, like this example. Thickness is 3 mm, also rounded corners. The detail is simple, but I got confused in numerous settings and templates, and the help tooltips don't look clear enough. Can anyone help me?
  • dirk_van_der_vaartdirk_van_der_vaart Member Posts: 559 ✭✭✭
    Do you just want a flat pattern?
    https://cad.onshape.com/documents/ab85317501e66bb0af3c780a/w/565d468d3c78d77c0b181756/e/83f5ab423d4c01b663aa9158
    Just Copy and edit, adjust the dimensions to your liking and you are ready.
    Use the rollback bar in the Partstudio to see how it is done.
  • alex_vestaalex_vesta Member Posts: 4
    2D drawing will be enough, but 3D drawing will be good, as I need to give the drawing to the craftsman to make the part. Previously, I used SmartDraw CAD drawing, for simple figures it turned out to be quite handy, although my drawings did not always look very professional.
  • alex_vestasalex_vestas Member Posts: 63
    Thank you. I switched to PartStudio 1, then created copy, but can't get how to change dimensions. Dragging borders by mouse don't work, can't find what instruments/menu I should use.
    edited January 2024
    Double click on the sketch you want to edit, then double click on the dimension you want to edit.
    After that go to the drawing and click on update
    Can't understand how to change the proportions of detail: I want increase or decrease part of 2D drawing, say in top view: clicking on any line of 2D drawing doesn't allow drag and move the target line. Clicking on dimensions value open small settings window where I can specify values, but without 'save' or 'cancel' button. Also, where is 'Update' button?
    You should edit in the Part studio not in the drawing.
    The drawing update button is on the left top corner.
    And maybe its better to have a look at the learning center or do the Quickstart
    I tried in Part studio, but nothing changes. overall, looks quite difficult to learn
    Double click on sketch 1 and edit the dimension you want
    After ediiting the dimensions in Part studio, I see some parts of the detail in 'Drawing 1' tab went beyond the boundaries of the sheet, and stuck together with the top view . How to resolve this?
    I'm stuck also, what you want is realy very simple and creating a bracket like this and creating a Drawing of the bracket only take,s 15 or 20 minutes to create if only you would invest some time learning the basics of Onshape.
  • lukas_szwugierlukas_szwugier Member Posts: 11 PRO
    Hi alex try to change drawing scale.
    lukas, Thank you very much.
    I wanted to add 90 degree angle mark between the detail walls. I read manual: Part Studios > Sketch Tools > Dimension. I applied angle mark in 'Sketch 1', but it remains hidden, and also does not shown on the main 'Drawing1' drawing.
    edited January 2024
    It seem's to me that you are confused about a drawing and the sketch in a Part Studio.
    The editing of all the parameters, dimension,s angles you do in the Part Studio.
    And then you create the Drawing with all the neccesary view's and dimension's.
    You only have to do this once, after editing the Part Studio just click the yellow update icon.
    regarding the OnShape help docs, so the “Drawing” tab is not as independent container, but a part that is subordinate to the Part Studio container? After editing model in Part Studio, we need generate a new Drawing tab(version)?
    No, just click the than Yellow update button
  • rick_randallrick_randall Member Posts: 397 ✭✭✭
    I'm hearing a lot of confusion here - see if this will help. A part studio sketch is used to create a 3d model, a 3d model is used to create a drawing which is then used to make blueprints. These steps have to be done in sequence, and to edit something, go to the previous step to make changes. I.E. make changes to model in the sketches - or make changes in drawing by changing the model (model will automatically update from sketch - but drawings need to be manually updated with that yellow button Dirk has described) Sorry if this seems overly simplistic, but I can remember the struggle all to well.
    I want change dimensions in detail:
    https://cad.onshape.com/documents/d7b1b8692866df96cbe6053d/w/f06bc1656a6a51d877776b2d/e/aab2055482980d4ec9195f01
    In Part Studio1 tab, which left menu I should right click and edit:
    Scetch1
    Sheet metal model1
    Scetch2
    Scetch3
    I want specify dimensions:(with 3mm thickness of the metal):
  • hiral_patel023hiral_patel023 Member Posts: 2
    You can double-click the sketch in the feature tree (like Sketch 1), then double-click any dimension to edit it. After updating, go back to the drawing tab and click “Update” to reflect the changes. To show bend info, insert a Flat Pattern view in the drawing, it'll include bend lines and notes automatically.
