Turn off constraint drawing ie.. old school
25 years of drawing and I hate constraints. It's like a child drawing sloppy sketches and an adult has to come back and fix everything with constraints and dimensions. Why not draw it right the first time, and skip all the extra time consuming work to define and constrain everything.I'm about to glue my control key down.
Is there a way to draw without using ANY constraints, or turn them off completely? I don't mean hide them, I mean turn them off.
Try the following and you will see my point.
Draw a corner to corner rectangle, then rotate it 45 degrees. You can't rotate it unless you delete all the constraints. This only takes 6 mouse click using the old school methods, but impossible with automatic constraints.
4 clicks to draw and rotate a square. Not possible with constraints. They are only good for people that make changes. Just draw
Also, have you tried,
to make an angled rectangle in 3 clicks?
