Lost Sheet Metal Table
peter_cuthbertpeter_cuthbert Member Posts: 56
Good Afternoon Folks
I think I have a typical beginner problem for which it is not easy to find a solution in the Help section.
I have a sheet metal part which is complete. In the Document I have a Part Studio tab in which there is nothing while in the Assembly Tab there sits the part.  It is not an actually an assembly but just a bent flat sheet.  What I am seeking to do is to get the flat sheet view and then print out the part as a flat sheet DXF.  I have done exactly that with several other single parts, but always from the Part Studio.  I think, but have not been able to prove, that one cannot use Sheet Metal Table button from an Assembly, which does make sense.
I have no idea how I have got into this mess, but to try to get out of it I have tried to copy the part into the part studio (does not work) and also tried to import a STEP file of the part back into the part studio.  That simply created several other tabs but left the Part studio empty.  None of the imported STEP file tabs show the Sheet Metal Table button.  I have tried re-load page and re-boot which are offerd elsewhere on this site as solutions to a lost Sheet Metal button. Niether worked.
Can any body offer me a cut and paste trick to get the part back into the correct place?  I have never been able to get Onshape cut and paste to function...
The offending part is to be found here:
Regards
Pete
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,895
    Your Document contains an imported part (dumb solid, not sheet metal), a Part Studio with a Derived feature (dumb solid, not sheet metal) and no Assembly tabs. If you want to convert it, create a Sheet metal feature with the Thicken option.
  • peter_cuthbertpeter_cuthbert Member Posts: 56
    Many thanks for that suggestion. Apologies for not acknowleging it earlier.
