Can I change username
I don't know if I missed anything but I cant set a username and wasn't given an option to do so, and my username has been set to luke_Jones800.... I wouldn't call that ideal. Im aware its a novelty but this is my identity and all others see of me at first and having my full name shown (which while Im fine with others may not want there full name shown) ended with the number 800, which is not something I would want slapped on my name, is not a good standard. Please let me know if their is a way of changing it or if I missed setting it in the account creation.
    _Ðave__Ðave_ Member, Developers Posts: 712 ✭✭✭✭
    edited February 2016
    Click your name drop down (top right corner of your Onshape screen) and select manage account. There you can change your name in both Onshape and this Forum.
    _Dave_
    BlåhajBlåhaj Member Posts: 4 EDU
    I had a similar issue, where I figured it out but it didn't display on forums even though that's the purpose of the username. I tried changing it within my forums profile and it said I didn't have permission.
    StillMakerStillMaker Member Posts: 22 EDU
    I have the same issue. I edited it in my onshape profile but my username on the forums is still the old one.
    NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,436
    Try signing out of the forum and signing back in again.
    Thank you @NeilCooke, that worked.
