Improvements to Onshape - February 2nd, 2024
February is already upon us, so of course we're due for another Onshape update!
First though, we have an exciting announcement:
For more information, please see the announcement blog post, as well as this forum thread.
As for this release, we've got some exciting new features for design workflows, as well as a handful of useful drawings improvements. Let's take a look!
Sheet metal bend is a powerful and capable tool. Please take a look at the full help documentation, including more advanced examples!
Surfaces, sketches, and composite parts are also included in the parametric insert.
If you insert a Part studio to an assembly as rigid but wish to break that link, you may do so by right-clicking on it in the assembly instance list and selecting Dissolve.
ONSHAPE VISION APP FOR APPLE VISION PRO
We're delighted to share the release of the Onshape Vision App for Apple Vision Pro. Onshape Vision offers a whole new dimension to product development by bringing 3D digital designs into our physical reality in a way that feels very natural. Users can intuitively explore 3D CAD models with their hands, eyes, and voice – there are no external buttons or controls.
PART STUDIOS
SHEET METAL BEND
You can now define a Bend in a sheet metal face using a sketched line or curve (including an edge). This will greatly improve modeling from the sheet metal flat pattern workflows.Sheet metal bend is a powerful and capable tool. Please take a look at the full help documentation, including more advanced examples!
IMPROVED MATE CONNECTOR USABILITY
Mate connectors no longer require an Owner part, but now can be owned by virtually anything. This means they can be used in many more applications, especially in layout-based design workflows.ASSEMBLIES
INSERT PART STUDIO AS RIGID (PARAMETRIC PART STUDIO)
You can now insert an entire Part Studio into an Assembly as rigid, creating a parametric link. If a modification is made in that Part Studio resulting in the creation of a new part, the new part is automatically inserted into the Assembly as well. Similarly, if a part is deleted from the Part Studio, it is removed from the Assembly as well.Surfaces, sketches, and composite parts are also included in the parametric insert.
DRAWINGS
AUTOMATIC INSPECTION ITEM NUMBERING
You can now automatically number and place Inspection symbols on your drawings. You can choose to insert the symbols to annotations in any number of selected views, an entire drawing sheet, or all sheets in the drawing at once.DRAG AND DROP INSPECTION SYMBOLS
You can drag and drop Inspection symbols between any unassigned annotations. Moving the Inspection symbol automatically updates in the Inspection table.
SHOW/HIDE HIDDEN EDGES FROM CONTEXT MENU
You may now select and show specific hidden edges in a drawing view, without having to show all hidden edges first.REFERENCE CENTER SELECTION - CENTERMARKS
A new Reference center checkbox has been added to the Centermark dialog under the Circular option.
ALIGN CENTERMARKS TO AN EDGE
You can now right-click and select Align centermark from the context menu to align centermarks to an edge, sketch, or centerline.
AUXILIARY VIEW OF A CROPPED VIEW
You can now define a Auxiliary view from a parent view that has been cropped.LEARNING CENTER IMPROVEMENTS
NEW COURSE - NAVIGATING A DOCUMENT
Navigating a Document introduces new users to Onshape Documents. Learn how a document goes beyond traditional CAD files, and master tools to organize and extract data from Onshape documents.Please take a moment to try out these new features and improvements and leave your comments below. For a detailed list of all the changes in this update, please see the changelog.
Remember: The updates listed here are now live for all users when creating new Documents. Over the next few days, these features will also be available in Documents created before this update.12
https://thesmoothcut.com/
Adding mate connectors to sketches is cool, but you STILL can't add it to composite parts, which is very frustrating.
Mate Connectors attached to sketches and curves is huge for how I like to design things top-down. Sheet metal bend means I can retire @MBartlett21's Fold SM. Parametric part studios are going to be very helpful for a lot of applications. All the drawing and inspection updates are making Onshape Drawings that much more competitive.
And bend via a sketched line is great too.
Twitter: @BryanLAGdesign
Is the age of constantly rebuilding assemblies after part studio changes finally over?
AND
I get to mate my sketches!
In the same update? Amazing work onshape!
And now I want a VisionPro. I knew ya'll would come out with something, but wow on day one? Great job.
Me too! Can't wait to see if the onshape version will cross over cutouts in the sheet metal?
Make an weld assembly and subsequent part and drawings in a proper way has been almost impossible in Onshape.
I hope the new insert part studio as rigid can make a change, I will check it out.
En este enlace podéis ver las Novedades de Onshape en español:
I'm happy we can now export in Y-Axis up.
On of my customers always requests that, so I always had a separate assembly with the object on its side.
Glad I don't have to do that anymore...
Mate connectors on sketch, that is something I've been trying to do for a while.
what does this mean?
If someone gets the Apple Vision, please let me know your take on it
If a variable is being used in a Part Studio and is renamed via the Variable Table, the rename would propagate through the features using it. Now this is also true if the variable is created in a Variable Studio and Insert into all Part Studios and Assemblies is enabled.
ex.
This FeatureScript allows you to create double sketched bends.
This Macro is included in the Onshape C2i Business program that we provide to all our Onshape clients.
" . it will enable to use a part studio insted of a sub ssembly special if there is no movment...
You just saved me hours of work once again. I am blown away. A feature I didn't even know I needed. Bravo!
