https://cad.onshape.com/documents/5d8da63844bedebe5cff72b1/w/96a36142be717fc84a504e3f/e/629230d0d394845d93416361
The Onshape standard was always to do multi-part part studios.
That's how you get your designs super parametric and quick. You share the same sketches and dimension clearances off other bodies directly in one studio.
Who told you one part per studio?!
There is a rabbit hole you can fall into though, you still want to break down your part studios into smaller chunks.
I like to use the rule of thumb, keep the feature tree under 100 features or so.
So for example, make all the parts of a linkage arm assembly in one studio.
https://cad.onshape.com/documents/875a31545b88515f455b1903/w/60363b016e2d28df08ca502b/e/103da319c1aa224a5eee9915
The warning is telling you to move the part studios into multiple documents.
Which may be where you are confused.
That and you're forcing the highest tessellation on some parts
That's a resource killer.
The remaining issue may be your computer?
I'm running in edge on a new laptop, and it all loaded up in a couple seconds, I'm getting 100+ fames a second rolling around.
Here are what your stats look like
compare that to a couple of our projects
Loads up an about 20 sec. gets around 30-40 frames a sec.
Here is the close-up of the stats:
it's broken into 9 sub documents
60% of everything shown is only created with these 3 part studios:
So, you are nowhere near the cap of what is possible.
Personally I hate multi-document design, but when you have large installations (such as what I showed)
Then it just makes sense to break it down that way.
Since most of what you have drawn are tubes that are welded to eachother.
I would have made one part studio drawing a simple tube.
Then make it configurable to any diameter/wall/length.
You would have been able to make most of your structure from just that
Not welded but separate parts with clips and riveted together....
there are 3 main possible sub-assemblies...front spar, rear spar, and tubes connecting inbetween.
Without detailed study of your extensive project perhaps you can quick answer...
I need to be able to edit tubes connecting ....so a question I have is :
say I have an assembly made up of 3 subassemblies which are in 3 separate documents
am I able to edit in context in the main assembly (I would hate to spend days constructing to find out answer is NO)
Can you post a link to your project?
Could you please get in touch with support team and share the use case where the parts are missing in rigid part studio even if they are not deleted from part studio.
I was so focused on the Vision Pro update that I missed some of the others
Parametric rigid part studio inserts into assemblies!!! This changes everything.
This is fantastic, thank you team!
Hats off to whoever wrote the Bend tool. It has some nice options
