laser cut boat hull
madeline_chan
Member Posts: 1 EDU
How do I make a boat hull, and eventually laser cut it? I want to make it in strips on the side, using laminate/veneer (not sure of material yet). This is prototype, actual one will be made with 3 mm wood
https://learn.onshape.com/
You might check out this resource here. There are a few custom FeatureScripts that might help with your intended outcome. You will need the modeling skills to build the boat in Onshape. As mentioned before, head to the learning center to work on that first.
Best of luck!
https://www.onshape.com/en/blog/perfect-3d-benchy-custom-features
