Missing dimensions on drawings?
JPMJPM Member, csevp Posts: 23 ✭✭
Any idea how to fix a free viewer not showing dimensions on drawings? Looks fine for licenced viewing.
  • PeteYodisPeteYodis Moderator, Onshape Employees Posts: 566 image
    @JPM This is likely a browser or browser security restriction issue.  I'd have them try a different browser to start with.  If that is not successful, please have them submit a ticket from the device they are using and we can help diagnose.  Free users can start a ticket from the help menu under "Contact support"
  • dirk_van_der_vaartdirk_van_der_vaart Member Posts: 561 ✭✭✭
    Refresh your browser or do a system on the upper right corner under the ? button
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 1,035 PRO
    Slightly off topic, I always test a link to give to a non-account holder by opening the link in a private browser window. Then I can see what they will.
  • dupont_florentdupont_florent Member Posts: 2
    Hello,
    I have exactly the same problem, I have refreshed my  firefox browser, tried on a another browser ( chrome), but the problem persists.
    Have you an other solution which I can explore please?
    thank you very much for your answer
    @dupont_florentplease submit a ticket from the device you are using and we can help diagnose.  Free users can start a ticket from the help menu under "Contact support"
