Improvements to Onshape - September 1st, 2023
13»
  • Member, Developers Posts: 3,947 PRO
    Ooh this sounds fun! But can we make it so that each of us can pick our layout? So for instance, there could be 50+ feature requests on the configuration list but each of us can make our assembly of the 25 we think will be done first and arrange them how we think will yield the highest probability of a Bingo. The assembly can then be configured with each of the participants (25 configured features in each one).
    Absolutely
    edited September 2023
  • Member, Developers, Channel partner Posts: 863 ✭✭✭✭✭
    En este enlace podéis ver las Novedades de Onshape en español:
    https://youtu.be/1bfQIf6m19c
    🕒 Más vale tarde que nunca
    Onshape no para y a veces es difícil seguirles el ritmo, especialmente cuando se acumula mucho trabajo, como suele pasar a la vuelta de vacaciones.
    🕒 Better late than never
    Onshape never stops, and sometimes it's hard to keep up, especially when work piles up, as often happens when returning from vacation.
    Un saludo,
  • Member Posts: 60 PRO
    This "convert to expression" is so close, if you make it possible convert to expression query input parameters the Onshape will transcend the whole another realm in automation
