laser cut boat hull
https://learn.onshape.com/
You might check out this resource here. There are a few custom FeatureScripts that might help with your intended outcome. You will need the modeling skills to build the boat in Onshape. As mentioned before, head to the learning center to work on that first.
Best of luck!
https://www.onshape.com/en/blog/perfect-3d-benchy-custom-features
