parts with variable parameters for use in assemblies
kees_bijker
Member Posts: 170 ✭✭
Hi all,
I was wondering if there is a way to "lock" a variable in a part somehow and then to create another part with a different value for that same variable?
The reason is I would like to use the same basic part in one assembly but use different lengths for instance. Every time you change the variable in the part studio, the part in the assembly follows suit.
Is this possible or are we going to need a feature script for this?
