Using midpoint to align entities
neil_preston
Member Posts: 12 ✭
I cannot seem to make 'midpoint' work in any useful manner. If I select a tool, selecting the midpoint tool deselects the first tool. For example:
1. I draw a construction line perpendicular to a line segment. I want to align (move) the construction line onto the midpoint of the line segment. Nothing works.
2. I want to draw a 3 point arc with the center of the arc aligned with the midpoint of a line segment. Any attempt to select the arc and the midpoint cancels the arc selection. Same with a circle.
How can this be accomplished?
Or select the midpoint tool then the line and center point of circle. Arc/line is already drawn.
no need to hunt down mid point of construction line.
Mid point isn't always selectable when drawing an object.
This is what I want to do, and I find that I frequently want to do it. The blue line is the X axis. I want to center the red rectangle on the X axis. I tried dimensioning the distance from the end to the X axis at 8 mm, but it errored out with the message "sketch could not be solved." (That's why it's still red.)
It seems that I should be able to select the midpoint tool, then select a line to define the midpoint, then use the 'coincident' tool to bring them together.
However, I often need to center a line on a construction line or an axis or other similar structure.
It seems like I ought to be able to use the midpoint tool to identify the midpoint of a line, then use the coincident tool to align it with the construction line, or an axis, or other line.
What methods can be used to do this?
this is not an acceptable workflow. Any operation that requires creating extra entities that are redundant to already existing attributes of a design element is extra work. I want to SELECT the midpoint of a line, but there does not seem to be a way of doing that. In Solidworks, all you have to do is right click the line and choose "select midpoint" and then you can set that coincendent to the other line.
It seems you want symmetry around the X axis. If so try using a symmetric constraint with the line endpoints and the X-axis.
