Library menu
tecnico2_alve
Member Posts: 3 PRO
Good afternoon,
I was wondering if is any way to do a similar filter but using our own library.
Is there any Feature Script to do this (e.g. similar to beam )?
Thank you
Thank you
That could mostly be done using configurations. But only one part at a time, not nearly as sofisticated as the standard content example you show0
Thanks John, but this is not what I´m looking for.0
I'd also like my own content to show up as standard content. There is no way to do this at the moment, we are relying on what Onshape decide to add in. Open Source content would be good which is created either privately or publically and be able to be added via user preference to the Onshape standard library. I am also hoping vendors will get on board and add content.0
I know, but it's the best we can do for nowtecnico2_alve said:Thanks John, but this is not what I´m looking for.0 -
I too would love this ability mentioned by the OP with our own library; good idea @tecnico2_alve
Don't forget what was mentioned in this thead:
https://forum.onshape.com/discussion/9249/standard-content-component-requests/p1
Hmm...1
