Angle break view
yuval_taffyuval_taff Member Posts: 17 PRO
Hey everyone,
My device has a 45-degree angle at the tip.
With the current Onshape drawing you are able to make only vertical/horizontal and not with the angle as I need it to be.
Does anyone got any solution?
Thank you.
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,038 PRO
    edited November 2018
    Edit: sorry posted for section view solution. Then realized it said break view :(
    No, as far as I know vertical and horizontal are the only view break options. You may need to create a improvement request.
  • yuval_taffyuval_taff Member Posts: 17 PRO
    Hey,
    With the current Onshape drawing you are able to make only vertical/horizontal break view.
    Sometimes this two doesn't fit the need for angled devices, and you need an option for angle break view.
