Any Way To See What Feature a Constraint is Tied To?
christopher_graham586christopher_graham586 Member Posts: 47 ✭✭
It seems like there should be a way to get this information but I can't find a way.
For example I have a constraint in a sketch that is to a feature of some invisible part
Should there not be something like a ToolTip on each constraint saying what feature the constraint is linked to?
    If you click on the constraint icon it will highlight the entities it belongs to.
  • christopher_graham586christopher_graham586 Member Posts: 47 ✭✭
    edited December 2018
    I know that, but what if the entities are hidden?  For example a constraint to a point in sketch used to create a part, but then the sketch is hidden.
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,063 PRO
    Typically external constraints are blue, while those belonging to the sketch are white.
    That sorta gets you in the ball park when digging in.
    turning on show constraints and mouse over all the blue ones is a good way
