Split edge
MBartlett21MBartlett21 Member, OS Professional, Developers Posts: 2,064 ✭✭✭✭✭
I would like to split an edge of a surface, so I can use my edge change FeatureScript on it
IR for AS/NZS 1100
    @MBartlett21 This seems like an odd request.  Can you explain the use case other than so you can build a feature to mod edges?
  • jelte_steur_infojelte_steur_info Member Posts: 653 PRO
    @lougallo
    I have a use case for this. In surfacing i often want to split an edge of a surface 1 to create a surface 2 that is only meeting surface 1 partly. nowadays i have to convert the edge to a curve using composite curve now we can trim that curve. but it's a bit cumbersome. i also often end up splitting the surface in order to split the edges. but i end up with a whole bunch of smaller surfaces that would not need to be the case otherwise.
    so in my view a split edge feature could be very useful for surfacing.
    kind regards
    Jelte
  • EvanReeseEvanReese Member, Mentor Posts: 2,865 PRO
    @lougallo Same exact thing for me. It's great for surfacing workflows.
  • S1monS1mon Member Posts: 4,061 PRO
    Plasticity (also Parasolid based) makes it super easy to split edges and/or faces, and then later remove the splits. It also has the ability to add limit points to lofts, kinda like fillets in Onshape can be limited to an arbitrary point along an edge. Clearly under the hood it's possible to do this.
    Hey, so I started  learning featurescript so i created a split edge FS as a first practice feature. I noticed other attempts but they didn't all work as i'd like.
    I started simple with a position/distance split... the opSplitEdge also allows splitting with another feature like a face but that'll have to wait a bit.
    so if anybody else is looking for this feature: here goes:
    https://cad.onshape.com/documents/df7470bfcac6dbf738846c11/w/4e60241b9fc0b28698901775/e/671818721a239174621cf6b1?renderMode=0&uiState=65f323ee2da7d66653a8662c
    Added to my toolbar.
    It would be nice to have the point shown as a manipulator instead of the debug colored edges. You might want to look at @Evan_Reese's code for 3D Points.
    https://cad.onshape.com/documents/309e817bcaf616677a834985/v/2a5b0d5c7243e2a8e6a93479/e/b28795ae9aec5a245cccb936
    Or alternately, Evan could add an option to split edges...
    I could also see it being helpful to have a pattern of splits. I would pick either individual points to split - or I would pick a number of splits and it would do equal spacing (either by parameter or by distance).
    Evan's Facecurves has options for individual vs grid (pattern).
    https://cad.onshape.com/documents/a8fffe63f92001db50a75db9/v/4c0e6b481cc73c58be7d40ad/e/193257f65ba4c932585edbb6
    Another nice trick is that it has the ability to split a face with a U or V isoparm which is closest to a reference vertex. I could see a similar functionality being useful for the split edge tool.
    @jelte_steur814
    nice! I've wanted this feature in the past and somehow missed that opSplitEdges() existed. I added it. Feel free to use/remix any of my code. If you do I'd be grateful for attribution of some kind.
    edited March 2024
    Hi S1mon,
    I added Manipulators. thanks for the input.
     it was a struggle for a newb like me, but i managed and learnt a lot.
    for pattern splits, it think the best way to go would be to make a robust 'split edge by geometry' version. This could be a tab in this dialog in the future.
    that would work with all kinds of pattern features upstream in the feature tree. a curve feature pattern of a plane along one or more edges, would do the trick to create the geometry of a point pattern.
    This results in a much simpler split edge feature and UI.
    but that's for another day.
    thanks again,
    Jelte
  • MichaelPascoeMichaelPascoe Member Posts: 2,814 PRO
    RENDERCAD
    Updated to be able to split by entity
  • christopher_finiziochristopher_finizio Member Posts: 4
    i have a situation where split edge is needed a perpendicular needs the edge its perpendicular with to have coincidence or pierce between two edges so the polar wrap faces(i dont know know right now how to say it but) can have a Profile. so that would be a circumstantial reason onshape needs this.
