create a curved pipe inside a solid
lujain_al_marhabi
Member Posts: 7 ✭
I have this 3d solid design that I am trying to curve a "bent" pipe-like shape through. I have tried using sweep with spline for the sweep path but it's not working. It's a bit tricky to choose the plane or create an offset plane. I was following this tutorial:
https://forum.onshape.com/discussion/comment/20877/#Comment_20877
What I am trying to create is this: (two curved pipes)
Right Side view
Front Side view
and this is what I have so far:
https://cad.onshape.com/documents/a489d677d12306e4e6b6be7b/w/4db9eabfa413a217febbf7c6/e/4c4b4c19eb35d63c0ad9888c
Thanks
Right Side view
Front Side view
Thanks
john_mcclary
Member, Developers Posts: 3,996 PRO
I tried to create a video, but i'm only getting a black screen...
I linked a document you can try that uses 3d fit spline
https://cad.onshape.com/documents/b411711e7479410653d76cfb/w/20da4d278b4e5ce8124f7c08/e/1b5aed1536aa3ba590ac981b
5 -
john_mcclary
Would a loft from the end of the large diameter into the small diameter work for you?
5
https://cad.onshape.com/documents/7af5abc3ae90227eef17af69/w/b9848826a72b012472e928ac/e/3cabd04e279297bb51d665ed?configuration=List_CAlswpFSizLjTk=Default
This is what I got:
Again I am not sure if this would be a problem after printing it (3D printing)
