Help with dimensions
bill_daniels
Member Posts: 280 ✭✭✭
in Drawings
It's almost always a delight to use Onshape Drawings but occasionally creating a part drawing gets downright confusing.
For example: https://cad.onshape.com/documents/c5abfd5f654e251234f0bf96/w/f9c22e580d59ee9961fd8da4/e/a39da6314d8d7b289aa82c8e
The 'scallop' is a 1.122" diameter cylindrical surface set at 10 degrees to the plane of the part. The exact location of this 'scallop' is important so it needs dimensions. In the past, I would draw a center-line and dimension to it but the OS centerline tool needs end points. Can any of you "Pros" give me a hand?
You can show part studio sketches in a drawing by right clicking on a drawing view. See show/hide sketches on this help page:
https://cad.onshape.com/help/Content/drawings-views.htm?tocpath=Drawings|_____4
"Show or hide selected sketch from Part Studio." (Incomplete sentence - by doing what?). "When the Show/hide sketches dialog opens, select the sketch from the menu." (Indefinite pronoun - What causes it to open?)
I will definitely forward this to our documentation team to take a pass over it, but the idea is that all of those items are under the heading that says: "Modifying views through the Context menu (RMB)". It's trying to tell you that if you RMB (right mouse button (right click)) on a view, there will be an option that is called "Show/Hide sketches...". Then that incomplete sentence is intended to mean "[When you click on the right click menu item called 'Show/Hide sketches...', it allows you to] Show or hide selected sketch from Part Studio."
Thanks for the input, and let me know if you're still having trouble.
