How do I determine the folder location of the part I'm currently viewing?
kenvidia
Member Posts: 4 PRO
How do I determine the location of the part studio that I am currently viewing or working on?
It has happened to me several times where I am working on a larger assembly which has linked parts from elsewhere. Some of them I might like to use in yet another assembly.
How do I determine where these parts are actually located? The best method I have now is to open them, then return to the main Onshape home screen and click on the part in my list of recent opens. Surely there is a more direct way? Is there a way to see where linked parts are coming from within a parent assembly without opening them?
What about seeing a list of assemblies which use a given part? (ie. A list of places where the current part is linked). It would be handy to know what the knock-on effects will be if I modify a given part.
5
I would like this as well.
Could you please create an improvement request?2 -
Yes, I too find it difficult to find document locations1
This is an issue I have also. I tried using labels to find things easier, but I can't figure out a way to select multiple labels to refine my search.
I do also.
I think that Google drive does a great job of this, and I think something similar could work well for Onshape Documents:
The little folder icon next to the File Name can be clicked for information, or to actually move a file from one location to another while you're in the file. This is a super nice feature!
Since there doesn't appear to be an answer to my question, I've created a feature request here:MBartlett21 said:I would like this as well.
https://forum.onshape.com/discussion/11507/determine-folder-locations-of-current-part-studio-and-linked-parts0 -
voted it up, it's worse when working with other people's stuff.
You can switch to it, but you still don't know where you are.
