Is There a Method To Create a Sketch Template?
larry_hawes
Member Posts: 478 PRO
I am forever creating a construction line on the x and y axis for every new sketch. Is there a way to make those lines 'sticky' for every new sketch or when opening any new sketch have them (among other items if wanted) already placed in every new sketch?
john_mcclary
Member, Developers Posts: 4,046 PRO
Typically the default planes are sufficient, it is very rare you should need to explicitly define axis if you are coming off of the origin.
5
Thanks again
