Boolean with Import of Surfaces?
nick_hanigan
nick_hanigan Member Posts: 10 PRO
Hi,
I used the Onshape public server to search for the Samsung S10 tool / model.  I found a good reference by Rob Cassidy, which imported a file from SolidWorks:, it is here: https://cad.onshape.com/documents/b5413e753843b3dbfd1dce12/w/afb70071c17b9b8dbe44e897/e/eafe6c770e5d980659ac093f .
I designed around this part a case.  I wish to Boolean subtract the S10 model from my newly designed case.  The Boolean command won't work and I suppose this is because the Imported file does not constitute a solid object and rather is a collection of faces.  I've had a quick look at the fill command between all the faces with no luck.
Does anyone have a suggestion on how I can eventually be in a position to complete the Boolean command?
Thanks in advance,
Nick.
    Hi @nick_hanigan - you can try the Enclose command which will allow you to make a volume based on multiple surfaces, but if they are really bad that probably won’t work. You could also try using the Boolean Plus feature which can be found under the “community samples”  filter in the “add custom feature” dialog (+ icon top right) - this will let you Boolean surfaces.
  • nick_hanigan
    Thanks Neil. I will try both on Monday and report back.
    You should also try the Fill Gaps custom feature as well (probably try this first). It will try to make the surfaces into a solid.
  • steve_shubin
    steve_shubin Member Posts: 1,118 ✭✭✭✭
    edited August 2019
    @nick_hanigan
    Curious as to the Vote Down. Myself — I’m of the belief that stepping through the features list of a document, to see how somebody made something, is one of the best ways to learn Onshape.
    You said — The Boolean command won't work and I suppose this is because the Imported file does not constitute a solid object and rather is a collection of faces.
    Below is a GIF that shows a cross-section of your imported part. That hatching shows that it is a solid
    If it were not a solid, here’s what it would’ve looked like
    Stepping through the document I posted, would have shown how to do the boolean you were asking for.
    If you’re unfamiliar with how to go about stepping through the features, you might want to let people here in the forum know. Somebody might help. Maybe even someone that got a Vote Down. LOL
  • nick_hanigan
    Oh, so sorry, I am new to the console and used your solution and meant to give you support.  I see you have helped others and am really appreciative of the fact that you were going beyond a standard answer.  I think I have corrected it, if not let me know.   Thanks again.  NH.
  • billy2
    If you're working with surfaces, boolean isn't your friend.
    I split the surface 1st, then delete the face 2nd. Why don't they combine these 2 into a trim command? I don't know and stopped asking. It's actually easier to debug when they're separated especially when performing complex operations.
