Boolean with offset does not work on complicated fillet surfaces
In this document there are two Boolean. The first leaves out the two surfaces that cause a failure. The second only has the two surfaces that cause the failure.
The offset of 0.015" is being used. Without the offset it works.
Initially I selected 0.015" offset all given that is the desired result.
Why doesn't this work?
  • dana_kelley262
    dana_kelley262 Member Posts: 31 ✭
    Never mind............. missed selecting the small wedged faces in the move face
  • steve_shubin
    steve_shubin Member Posts: 1,118 ✭✭✭✭
    edited September 2019
    @dana_kelley262
    I don’t know why the boolean with offset failed.
    But if you’re interested in a workaround,
    see the document below.
    https://cad.onshape.com/documents/68bc73df32d1e5351be70c4f/w/16f68abd9376f30ca3cdfd84/e/d7696fbbd6d958faf1c8209c
  • dana_kelley262
    Thanks for your feedback. Interesting solution. I've submitted a bug report to find out what the issue is before moving forward.
  • steve_shubin
    @dana_kelley262
    I got it to work by using a single boolean — the way you wanted it to work
    I used REPLACE FACE to eliminate the lines shown below. Then I was able to use a single boolean with offset on ALL THE FACES.
    https://cad.onshape.com/documents/4ae02264d7f77c75f8239e4a/w/b96aafb51f9cc03b34ab1898/e/7e3aa785b65a1369e2142982
  • dana_kelley262
    I saw that the no offset worked but did not realize there was a second step that could be used to add the offset. So one would ask this question. Why not break it into two processes? No offset followed by adding the offset. A hack perhaps but it eliminates future head scratching and hides it from the users.
    This solution worked just fine so Ill be moving on. :)
  • dana_kelley262
    It did not quite work after all.
  • dana_kelley262
