Next year improvement request
bryan_lagrange
Member, User Group Leader Posts: 985 ✭✭✭✭✭
in General
With another year of great Onshape improvements in the books, what improvements would you like to see for 2020?
Here are a few of mine:
CHANGE ORIENTATION OF FLAT PATTERN IN DRAWINGS
https://forum.onshape.com/discussion/8499/change-orientation-of-flat-pattern-in-drawings#latestSKETCHING IN DRAWINGS
https://forum.onshape.com/discussion/9784/sketching-in-drawings#latestCHANGE DIRCTION OF BENDS IN FLAT PATTERN
https://forum.onshape.com/discussion/9404/change-dirction-of-bends-in-flat-pattern#latestCHANGE THE DEFAULT CALL OUT OF THE ANGLE IN DRAWINGS TO THE COMPLIMENTARY OF THAT ANGLE
https://forum.onshape.com/discussion/8500/change-the-default-call-out-of-the-angle-in-drawings-to-the-complimentary-of-that-angle#latest
My top 5 in addition to performance improvement
- Color by face & feature
- Change part / face color and part transparency in assembly
- Decals / images on part and assembly
- Exploded views
- Enhanced variables (use any given dimension + global variables w/o using fs)
My dream 5
- MBD (model based definition ie. 3d drawings to use instead of 2D drawings)
- Animation studio (assy movement & explode)
- Easy way to embed live model into website/webshop with parameter input
- Render view (comparable usability and quality of Keyshot)
- Stay awesome
So, I don't see a problem repeating the needs in many places...
Between Bryan and Konstantin, they got most of my biggies listed
Also the animation thing...If it's good enough for the OnShape front page to have a nice animated assembly, then I WANT IT TOO!!!
Ability to pull dimension in from model on a drawing.
And the sharing thing mentioned above. It would be good to be able to embed a shared view in another webpage.
