Flat-Head Screw Hole
PAH
PAH Member Posts: 18 EDU
How do I place Flat-Head Screw Holes on a curved surface? I need to specify the location so that they align with the mating part. I have included a simple sketch and would like to add the holes on the inside of the part so the screws point outward.
https://cad.onshape.com/documents/f8e8d876e4101e30254a93c4/w/7eb44791a82c89da28cc94b4/e/34a5ed6a6252aafee747a236
Thanks for any help,
Paul
  • john_mcclary
    If you click this button
    Then select a line that intersects the center point of the face, it should work...  don't forget to select parts for merge scope. And flip direction as necessary
