Create document in new tab.
tim_hess427tim_hess427 Member Posts: 648 ✭✭✭✭
I wish there was a way to open new documents in new tabs. There are certain stages in projects where I'm creating several new documents in short succession and its a pain to keep re-opening the "Documents" page. At a minimum, changing the default behavior would be an improvement. Whenever I'm working, I like to keep one tab open with the documents page at all times.
If you're debating whether this is important: Just imagine that Finder or Windows Explorer closed every time you created or opened a document. Wouldn't that be frustrating? Why should Onshape's behavior be different?
P.S. - I know that I can right-click on a document and open it in a new tab, which is why I'm specifically asking about creating new documents here.
    @tim_hess427 This seems to be more of a browser behavior.  If you hold down SHIFT and click you get. a new window and if you hold down CTRL/CMD click you get a new tab.  These are universal in browsers.  Give that a try.  Default behavior is to navigate to the destination .
    Middle click does this for me.  Browser can also be set to open all links in new tab by default.
