Vertical og Horisontal alignment of Diameter Dimensions
Ketil_Volland_PrivateKetil_Volland_Private Member Posts: 29 ✭✭✭
Optional alignment options for Diameter Dimensions. It would be a good option to be able to choose alignment (or direction) of the diameter options. Either along a vertical or horisontal axis. Currently the diameter dimension sits radially to a circular dimension. See image for suggested options (in red).
    This is set by using the Gaps and extension area under Dimension in the Drawings property panel.  Today this is a global set but we will parse this down further as we mature Drawings.
  • Henk_de_VlaamHenk_de_Vlaam Member, Developers Posts: 267 ✭✭✭
    Hi @lougallo,
    lougallo said:
    This is set by using the Gaps and extension area under Dimension in the Drawings property panel. [...]
    Please can you be more specific? I can't find this setting.
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,056 PRO
    You can snap to quadrants with Shift+Q
    then you can add the diameter symbol in the dimension properties
    edited March 2020
    @john_mcclary,
    I am aware of this, but Lou talked about a global setting via the Drawing property panel.
  • Severin_123Severin_123 Member Posts: 47 PRO
    @lougallo are there any updates on this?
