configurations for hinge
derek_westwoodderek_westwood Member Posts: 34 ✭✭
https://cad.onshape.com/documents/21996e45feed49237c2bcc1a/w/d65e68b931fe697f2e15f5b9/e/7185304c7d7106e0963d623b
I have imported this hinge into onshape and want to create two configurations, open and closed, I have inserted a revolute mate which allows me to get two views of the hinge - open and closed - but how do I make configurations?
Thanks in advance, Derek
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,988 image
    The angle of the hinge can only be configured if the mate is a Fasten mate. A revolute is free to move so configuring the angular position of one of the mate connectors will not make it move. An alternative is Named Positions which can be found in the toolbar at the top.
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,059 PRO
    edited March 2020
    @derek_westwood
    You can configure more than just fasten mates.
    You will need to configure the limits for a revolute.
    Which means typing your value twice, Once for the minimum and Once for the maximum value.
    I only do this if I want a "free" configuration (one that I can still move freely like a revolute should)
    click the link below to see more
    https://cad.onshape.com/documents/3a2d8558d409e9e77d1e0c8d/w/e802f3db1ec4eded17750ab2/e/519b8366ea5020ee7b34b628
