How can easily locate the mate feature
Alex_Huang006
Member Posts: 12 PRO
In the assembly, we create mate features for assembly. When I want to edit the mate relation for one of the parts, I select it in the part trees. But we have no idea which mate feature is relevant to this part, because no mate feature is highlighted or selected meanwhile. (See below pic).
The logic here is that we have to check the mate features (i.g. "Fastened 1, ...) to see which part is related. What if I have big assembly with 100+ mate features, I have to check the mate one by one to look for the expected part to edit ?
Hi @Alex_Huang006 - it's not ideal, but the way to do this now is to right-click the part and select "Show mates". The mate will then be shown on screen and in the instance list.
Senior Director, Technical Services, EMEA5 -
See my improvement request here:
https://forum.onshape.com/discussion/10134/show-mates-under-each-part-in-assembly
5
In this way, will show all mates related to the selected instance, including all child and parent of this instance. But in fact, what I want is only to redefine the assembly of this selected part to its parent. So I still can not accurately get the mate, I need to check which mate is the one.
The correct logic should be "right-click" of the instance to get the "redefine" for assembly update.1 -
5 -
For sub-assemblies, you then have to expand the sub assy tree and select hide and mates so only the top level are shown which is very time-consuming. This is a very regular process I go through when fixing assembly mates and be great if it could be done with one click. @malay_kumar is this something that could be implemented?NeilCooke said:Hi @Alex_Huang006 - it's not ideal, but the way to do this now is to right-click the part and select "Show mates". The mate will then be shown on screen and in the instance list.0
