Public Standard Parts Library with "Private" Information
We all want a good standard parts library of fasteners, o-rings, retaining rings, etc. In order to keep this truly industry standard and to keep everyone's storage space small it would make sense for this to be a library of public parts loaded and maintained by OS. However, my company assigns our own data to the standard parts we use so we would need to be able to do that as well and for that information to not be public in OS. Once we figured out how to really use Toolbox in SolidWorks we were able to make it sing since we only had the fasteners in our system available to the engineers (with the ability to add as necessary). This kept the list specific to us and much faster to use.
I'd like to see a similar thing from OS. I'm suggesting an exhaustive standard parts library accessible to everyone, but with a means for us to easily identify the sizes we use for our company and attach appropriate data such as part number, description, vendor, vendor p/n, cost, material, finish, etc. This information would be private to our company and our engineers, but not available to anyone else. I'm thinking this would be like a spreadsheet for our company with appropriate links to the public library. Therefore, only this spreadsheet would be a company and therefore private document. When we go to insert a fastener we should be able to pick from our list of company standards and select from any starting point such as type, or size, or length, or part number, etc. All of this meta-data would need to be available as a property of the part so it shows up in our assemblies by our part number, not the industry standard number. Also, when drawings become available this information would need to be usable there as well as in assembly BOMs.
In the event of a modified part we should also have the ability to copy the public part to our private set of files and make whatever mods we want.
What do you all think of that? How would you want to see standard parts implemented?
- - -Dennis
- - -Dennis
9
But I think your proposal of a centralised basis for libraries, able to be indidualised additively and privately, has strong merit.
I also got a message from @lougallo stating this would be managed by a third party and not OS directly. That's fine with me. I don't care if OS does this directly or indirectly, I'm just looking forward to its implementation so we don't all try to make our own versions. With all the concerns about file storage this is an even more important way to implement standard parts.
Twitter: @onshapetricks & @babart1977
I am hoping that Onshape can do something clever such that the solid file is public with all its configurations and that we only have a private document (shared within the company) that includes our selection of which of these are used by our company and our associated information of part number, description, material, finish, etc. This supplementary data file (like a spreadsheet) should be very small compared to the global solid file.
There would likely need to be several of these files separated by metric/imperial, type (SHCS/FHCS/HHCS/BHCS/Set screw/Nuts/Washers/etc.), but once one is done it becomes a template for the rest. Toolbox in SolidWorks has some legacy issues that keep them from overhauling it like it needs, but on the whole it works very well if a person just takes the time to figure it out. Onshape has the benefit of hindsight and learning from others (their modus operandi) so I expect them to do something even better.
Then you could have 'company parts' tab in your document.
If Onshape would provide possibility to derive / add part from link; you could just pick the right part and copy link --> insert into assy / ps.
I agree that perfect system for public part library is important at some point but not in my top ten at the moment.
Some of the issues I have with my current set up are.
- Copies of tabs inflate the size of the working doc. (Inter document references should fix this)
- Can not do a replace part and retain mates. This would require a "replace part" command in the assy module as well as a way to reference new part to old mates, SW's does with ease if the bolt is created from a common template or with a configurable toolbox bolt.
- Can not easily control the switching on and off of thread detail.
- Slow creation, a design table would speed things up
However when in use my current system does work well in Onshape. When I want to add a bolt I just copy and paste the tab out for the size series and drop the bits in the assy as required, fixing with fasten mate to predefined mate connectors. I can now also use the derived command to drop bolts into the part studio to design around if need be.Twitter: @onshapetricks & @babart1977
Imagine a situation where the ruling thickness for bolting flanges was increased, so that all M12x30 SHCS had to become 35mm long
In about 2009 or 2010 they added the ability to make discontinuous selections of part instances and change them all to a specified configuration, which was a major time-saver.
Creo's Family Table and SolidWorks' Design Table are very much the same thing. Yes, we need a similar functionality as a supplemental way to build and control configurations.
The original thrust of this post is for Onshape to provide a Standard Parts Library (fasteners) so that we don't all create our own, yet provide us with the ability to associate our own company's information with the subset of this master library for the fasteners in our own company's system. I expect that in the process Onshape will have to flush out the whole functionality of configurations, including the option for Design/Family table spreadsheet-type controls. You can vote for this Improvement Request here: https://forum.onshape.com/discussion/1407/public-standard-parts-library#latest
Agreed! Frankly, I like the way we can rename things in SolidWorks, from sketches to features, constraints to dimensions. I have all our installations setup to default to automatically prompt for renaming a feature upon its creation (because few ever go back and rename one once its been put even one feature in the past). I only rename a few dimensions, but they are ones we'd be using in an equation or Design Table or just want it to catch the eye when we want to make it easier to change a fundamental dimension of a basic parametric model (Pitch_Dia, for instance). This ability has been part of SolidWorks almost from day-one (or at least to the best of my recollection), and I've been using SWX since its initial release in 1995. Wow! Twenty years of a great product and I am looking forward to Onshape! That's faith in @jon_hirschtick and the team!
I'm really looking forward to the named dimensions and equations and Design Table equivalency to allow us to exploit the power of a spreadsheet (Google Doc?) not only for configurations, but also for more easily controlling and documenting the values of the different parameters. I'm still surprised at the number of people that don't know you can have incredible links to other sheets, even outside the spreadsheet of the SWX Design Table, in order to really make a parametric model sing! That is a lot of how DriveWorks does its magic. I want expect the same ability in Onshape.
I'm talking about simple one-time-only changes to the configuration of parts in an assembly, in cases where there were multiple instances of that same part.
What they added 2009ish was to eliminate a limitation: previously it was very easy to change the configuration of a single instance.
They eventually expanded that simple process so it worked for multiple instances, simply by making a multiple selection (not necessarily contiguous) from the feature tree, and then choosing the new configuration to apply it to the selected instances.
@dennis_20
Hi Dennis,
The functionality you're talking about here --> "I'm thinking this would be like a spreadsheet for our company with appropriate links to the public library. Therefore, only this spreadsheet would be a company and therefore private document" is available in openBoM. It called "inventory tables".
I'd be very interested to discuss a practical use case - I'm sure there are things we missed, so we can think what are the gaps and how we can close it in the next versions of openBoM.
Here is the short video that demo how to create inventory tables in openBoM
More information about how to use inventories in openBoM can be found here - http://tutorials.openbom.com/
openBoM integrated app for Onshape is available on App Store. I'd be happy to answer on questions and show a demo.
The scenario I'm very interested to validate is how to connect Part in Onshape (based on Name or maybe onshape Id) with part Number in BOM. Onshape is a bit aloof when it comes to Part Names.
Appreciate your thoughts, comments and feedback.
-Oleg
Your openBOM tool is interesting, but it is not what I am asking for at all. What I am asking for is something akin to the Toolbox in SolidWorks. I would like Onshape to supply a thoroughly vetted library of standard fasteners that comply with a variety of industry standards. This would be preferred over everyone creating their own fastener files. If everyone creates their own fastener files there is unnecessary duplication of effort with a huge range of non-compliance to standards, not to mention an incredible proliferation of files - in short it will be a big mess.
If Onshape were to supply such a fastener library as a public document that can only be edited by Onshape then they will control its accuracy. I would think that Onshape would be very interested in this for a variety of reasons, not the least of which is customer good will and overall smaller file numbers and sizes on their system. Of course any part could be copied and modified for non-standard situations.
I am not even interested in the FeatureScript functions that make it easy to create a fastener as this just makes it easy for a lot of people to create their own and proliferate unnecessary duplication. If we have nothing else then yes, this would be handy, but I really expect Onshape to provide a universal library of such things as fasteners.
Perhaps then your openBOM could provide the company-specific information we would also need, but first we need the standard library of fasteners from Onshape.
https://appstore.onshape.com/apps/Content
A big part of what I am after is a set of configured parts. You have pointed me to several standard part libraries that are very good for what they are, but really are just more convenient forms of what a person can get from McMaster-Carr.
In the SolidWorks Toolbox one of the great benefits is the ease of changing a fastener. For instance, let's say you have used ten M4X20 SHCS in an assembly and something has changed that you need to now change these to M6X25 SHCS. Simply selecting the ten fasteners you can change them all with a single command. That capability does not currently exist with Onshape, regardless of where the fastener comes from.
Thanks for your comment! Yes, indeed, these are two different problems. In case Onshape will provide standard library of fasteners, openBoM can be a tool to provide an information and get all attributes about fasteners into BOM.
Are you asking for tool that makes changes to parts when you add/change fastener in assembly mode? So that it makes holes etc. to fit selected fastener.
This would be great though needs some clearance preferences.
I suppose before that we will have 'configurations' and 'edit in context' (ie. edit part in assembly mode) since they are needed core functions to have this type of tool on top.
Good stuff and nice that we have active BOM preparing for future features!
One of the big advantages of configurations is that surfaces retain their internal identifications from config to config. This is essential for maintaining mates. For instance, in SWX the configured features that make up a SHCS are the same from size to size with only their dimensional values changing. So an M4X20 SHCS is mated with a hole on its bottom face of the head and concentric to the shaft. These are the same surfaces as another SHCS configuration, say an M8X30, so changing the configured fastener doesn't blow up the existing mates.
If the fasteners are distinctly different parts then their faces carry different identifications from part to part and the mates do not automatically hold when changing sizes. This is the case with the third-party fastener libraries that have been pointed to in this thread.
Data re-use is valuable and vital. Onshape has done a lot to foster this with their whole approach to cloud-based solid modeling. However, the economy and convenience of data re-use for something as ubiquitous as fasteners has been sadly overlooked in my opinion.
