This isn't letting me fillet this .5 inches
carlos_frias469
Member Posts: 9 EDU
I have been having trouble trying to fillet this object in the project. It keeps saying that it failed to generate properly but it only lets me fillet from .3,.2,.1, and anything in between those measurements up to 3.9. I fillet in other project and it doesn't have any errors. here are some pictures. the one below this one is I could extrude 5 inches
mahir Member, Developers Posts: 1,309 ✭✭✭✭✭Hi Carlos. Welcome to the forum. First, check the Forum Post Checklist for how to maximize your chances of answering your question. Second, I can't be sure what I'm looking at without a link to your model, but in this case I think the fillet is likely geometrically impossible, and that's why you're getting an error. The first picture works because you're filleting 2 simple 90deg corners. The second picture includes some sharp edges and a small radius. You can't add a radius any larger than the one that is already there. Hope that helps.
5
BTW for non-paid subscriptions, the forum is the correct place to get support.
I recreated a similar shape, and the largest feasible fillet was only .35.
Making the arcs tangent helped a bit and allowed me increase the fillet to .48 (almost .5). So bottom line, make sure your base sketch is correct.
EDIT: and yes I fixed the sketch tangent issue first
Like Neil was saying, without seeing the tutorial I can't tell what you're trying to accomplish.
