Templates
_Ðave__Ðave_ Member, Developers Posts: 712 ✭✭✭✭
edited August 2015 in Drawings
Hi all the following request are not extremely pressing but a few things that I would wish for in the near future.
 1  I would like an option to Choose a different template for an additional sheet besides the continuation template.
 2  I would also like to be able to insert a sheet between two existing sheets or before the first sheet.
 3  And I would also like to be able to completely change a template on an existing sheet.
  • brucebartlettbrucebartlett Member, OS Professional, Mentor, User Group Leader Posts: 2,145 PRO
    +1 for  all these.
    +1 - pretty standard stuff
    //rami
  • bobminerbobminer Moderator, Onshape Employees, Developers Posts: 50
    @da_vicki - Thanks.  Some questions / comments:
    #2 - Inserting a sheet between existing sheets, reordering sheets, etc.
                - Understood.  Makes perfect sense.
    #1 - Choosing a different template for additional sheets.
    #3 - Changing a template on an existing sheet.
                - Do you need to mix ANSI and ISO sheets in a single drawing?
    Bob Miner - Software Engineer / Dev Leader - Drawings - Onshape, Inc.
    @bobminer
     I don't have a need to mix ANSI and ISO sheets and would expect that anyone requiring to mix them would be few and far between.
    @da_vicki - Great. Thanks.
  • MaruMaru OS Professional Posts: 18 PRO
    +1 on these as well.
    Also want to note that I think some of the formatting being so tied to templates can be a little frustrating, for example it would be great to have control over some basic things like default scale, font sizes, and dual dimensions available without having to jump into a DWT editor.  Assume these might be planned but want to mention it.
